Unleashing The Beast
AngelPhoenix
Halifax, PA
The gains made by an intake and exhaust are usually at the upper end of the rpm range but at the loss of low end torque
More than half the people in this thread said there are no gains/no effect on performance…?
Also, if you go heavy on the pedal, won't you be hitting that higher rpm range even at lower speeds?
Why does it make you lose low end torque? Just trying to (fully) understand what I'm getting into here…
Scram1500
I'm sure everyone here including myself uses the butt dyno and do not know the true gain or loss.
More power at high rpm is like having something you need on the top shelf, you cant really reach it easily.
There is always a trade off, intake "restrictions" at low rpm generate torque but that restriction further up the rpm band becomes detrimental to horse power. If you look at a dyno graph of before and after cold air intake, you'll see minimal hp gains near the redline
ferraiolo1
North Central PA
Because of the “I spent money on performance parts so there must be gains” placebo affect.
Same with people thinking throttle body spacers work, and those little tornado devices they sold in the 90s that went on your intake.
AngelPhoenix
Halifax, PA
So is there NOT a loss in low end torque, and a gain in higher RPMs?
ferraiolo1
North Central PA
The gain at redline is minimal, some companies state you get around 15hp at redline. Which your average person will never feel especially on a heavy truck, nor is the average person at redline most of the time.
You wouldn’t loose any low end.
You’re over thinking it. If you want it to look/sound good, spend the money. If you expect any significant gains for the money spent, then don’t buy it.
AngelPhoenix
Halifax, PA
I sure am! lol
Did the same thing with my tires. Actually, I'm still doing it with my tires. Occasionally it's a blessing that leads to me making a really satisfying purchase. Most of the time it's a curse that erodes my sanity 😅
I truly appreciate everyone's responses and info, thank you!
c3k
What's "forced induction"?
"induction" and "aspiration" are terms used to describe "breathing" and/or airflow.
Once air is forced into an engine, rather than letting the engine pull it in, then you have "forced induction". The normal ways of doing this are with a super-charger or a turbo-charger.
The term to describe a non-forced induction engine is "normally aspirated intake", also abbreviated NAI.
And, FI is, of course, Forced Induction.
Hope that helps.
