BFGoodrich K02
Jbjorne
Anyone running a BFG K02 on a 22" wheel? Their sizes are a little goofy in a 22" and I'm curious what people are running without rub. Will have a 2" level and no air ride.
I can’t really help you, but those were the tires I wanted when I bought my 22s (they were backordered) and I’m still a little salty about it. Hopefully you have better luck than I did.
What size tire is on your truck?
I wanted them in 33x12.5x22, but I ended up with 285/50/22 open countries. (Which are 33x11.5x22)
I have stock 20’s and just put these tires on with a Mopar 2” lift/level and had zero issues rubbing and had the same, if not more, clearance between the sidewall and UCA. Tire size is 285/65/20.
EDIT: just saw this thread lower down in the forum:
