TRX beadlocks on a Limited
mastermayhm
Factory set, only rub when im turning, fully locked. can drop the truck all the way down to the load/unload height no problem.
color matching the center caps to the outside bead now.
That gives me a chubby.
Can you tell where/what they are rubbing on at full lock?
How bad is the rubbing when you're on an incline when entering a driveway or parking garage?
no rub on incline or curbs. i didnt think they'd fit without major modification. they are 34".... i might just let the tires rub down the little corner in the back of the wheel well until it stops, instead of actually cutting it up.
damn just noticed it rubs the upper control arms by the upper ball joint, need a spacer
Have you leveled your truck yet? IMO looks a little goofy so high in the rear and taking a nose dive.
