Glenn54
Have any of you guys ever installed air bags? Curious how difficult it was. Thanks.
What is the propose of this upgrade? You need it to level the truck when towing?Have any of you guys ever installed air bags? Curious how difficult it was. Thanks.
Yes, I want to be able to level out the truck, and trailer while towing.What is the propose of this upgrade? You need it to level the truck when towing?
Well. Depending on the system you're going to choose, it will vary.Yes, I want to be able to level out the truck, and trailer while towing.
Looks good.
Thanks Manny. I'm getting older but I do have some mechanical ability. I've rebuilt a few engines although it's been a long time ago, brake jobs, etc. I will give these air bags a try.Well. Depending on the system you're going to choose, it will vary.
In general, installing rear air bag lift is not considered hard. If you know what you're doing and it's not your first time actually working on a truck, it shouldn't take more than an hour or so to complete.
Airlift has great products and if you go with one of the AIRLIFT1000 kits, it will be very easy to install and use. It's a simple system that you fill up like a tire, look this name up( airlift 1000hd) and see what other members of the forum have to say about this upgrade.
It's a good, simple system.
Link to their website: https://www.airliftcompany.com/products/air-springs/air-lift-1000-hd/
If you did all of that - this project will be easy peasy for you!Thanks Manny. I'm getting older but I do have some mechanical ability. I've rebuilt a few engines although it's been a long time ago, brake jobs, etc. I will give these air bags a try.
