footwell lights
irondj
I changed my 2019 lights easy, seems they changed the 2021 footwell design. How do you change the bulbs?
I just had another member give me some info on this. You likely have the LED option and not the halogen bulb. Paragoptics was recommended to me and unfortunately, that is the only option that I have seen that will work so far.
Once you pop the light out of the lower dash panel and disconnect the harness, you can take a small pick or screwdriver to pry the plastic apart. This will give you access to the LED board inside.
can that bulb be replaced? they aren't very bright
