c3k
- Jul 22, 2020
Gents,
Looking at all the threads on AlfaOBD (even the big, stickied, one), I am confused as to what to buy to get this to work. (I'm running two other OBD scan/setting tools, but not AlfaOBD. My confusion centers on the hardware to get AlfaOBD to link to the BCM.)
As I understand it, I need to:
Buy and download AlfaOBD. That's easy.
The AlfaOBD instructions send you to this website: https://www.zautomotive.com/?s=&ymm_search=1&post_type=product&_make=Ram&_model=1500&_year=2021
It shows these items:
The assumption is that I need a Security Gateway Module to bypass the one-way comms built into the truck's OBD. That would be the $69 SGW module.
The next assumption is that I need the $29 Extension Cable to allow me to plug that SGW module into the truck's OBD wiring.
So...that's $100.
My question: if I buy the 2 items, will my truck's normal OBD port work? Meaning, does that SGW module just unlock the EXISTING OBD port?
Next question: Amazon has a bypass cable for ~$23. Here: https://www.amazon.com/Bosting-Adaptor-Chrysler-Programming-Connector/dp/B07S91VZXT/ref=sr_1_5?crid=PWO801WVQS19&dchild=1&keywords=chrysler+12+8+cable&qid=1635258116&sprefix=chrysler+12,aps,144&sr=8-5
Image:
Does this cable perform BOTH functions of the zautomotive extension AND SGW module?
Next, to have a wireless OBD experience, I should also pick up a bluetooth OBD dongle, like the OBDLink MX+, here: https://www.obdlink.com/products/obdlink-mxp/?ref=alfaobd
Image:
TL: DR;
If the above MX+ link is NEEDED, would I just plug into the truck's OBD port if I use the zautomotive extension and module?
If I get the $23 cable, it looks like it would bypass the truck's OBD port and that I'd have to plug the OBD MX+ link into the OBD port on the end of the red cable?
(The above is new to me: my existing software (RossTech VCDS for VW and multiecuscan for an Alfa Romeo) came with the hardware: an OBD cable with bypass built in, and a USB plug. So, I'd plug my laptop directly into the OBD port and the software would link up and work.)
I'm confused about needing two or three third-party items.
Thanks for any assist.
Ken
So...that's $100.
Image:
Image:
TL: DR;
Ken
