gpollman
- Dec 11, 2020
Been lurking since I picked up my 21 Laramie but havent really seen a definitive answer on this particular issue with my setup, so I am hoping someone can maybe ease my concerns. Just installed the King OEM 2.5 coilovers yesterday, had the preload set 10 turns down from the top per King to net a 2" lift (non-ORP), however after getting things back together and making the 30 mile drive home the front is still sitting about an inch higher than the rear -- I'm about 25" from hub center to fender on the fronts and 24" on the rear and havent had it aligned yet. I've heard some say that the front settles over time, but will I see an inch of settling or should I consider pulling the coilovers and having them adjusted again now? Thanks for any info.
