Trying to confirm 35’s will fit 2021 1500 with 2” level kit
Dcsnet
I am trying to find out for sure if Nitto Ridge Grapplers 35x11.50 on stock 20x9 rims will fit without issues on 2021 Ram 1500 new body style. Planning on using the Billstein 5100’s for the 2” leveling and also having the upper control arms changed for better geometry.
Thanks
Don
Should be fine. This is from their website, the bolded column in the middle is the approved rim.
35x11.50R20LT E 124Q20554021.034.7611.428.0-(9.0)-10.53525 @ 8070.41
The wheels aren't the issue, it's the tire width and backspacing as there's not a lot of gap between tire and UCA on factory offset.
@Dcsnet 11.5" wide you should be ok. It's when you move to the 12.5" wide that rubbing becomes an issue.
LOL... I read that wrong.. I read it as "if Nitto Ridge Grapplers 35x11.50 on stock 20x9 rims will fit without issues" as in, will fit on the rims... Good catch
Yes, very little room to the UCA, like less than 1/2” on 11.50 wide tires. 12.5” will hit and require spacers.
Not always here's a pic of mine with 35x12.50 on my factory wheels with no spacers
Thanks guys. I ended up going with the 11.50 and they fit perfect no rubbing!!
I’ve got 35x11.50 Toyo AT3 no problem. Ended up replacing the front factory struts with BellTech Off Road leveling struts. Runs great.
What did you set the Belltechs too??
Truck looks great!!
