ORG W/ Air Ride on 35's
Nick57
I just put 35x12.50R20 Mickey Thompson Baja Boss AT's on my stock Ram with the offroad package and air ride on the stock wheels. They fit with no rubbing! Here's before and after...
Truck looks awesome, and I’m glad you posted this as these tires just came on my radar in the last day or so. I did some preliminary research on them and most, if not all, of the reviews are glowing for these tires. Seeing you have these mounted might make my mind up on getting these.
It looks like you have the sport wheels, do you know if are they the same offset as the Bighorn night edition wheels (+19 offset)? How do they ride?
I don’t have an ORP or air suspension truck, but do have the Mopar 2” lift installed. So I probably have an additional inch over what you have. So this looks promising that if it worked for you, it should work for me.
Thanks for the eye candy in pictures, looks awesome!
Thanks! With the 2" Mopar lift yours sits close to where mine does in the "normal" setting. so yes these will fit. The offset of your wheel is the same. However you may or may not need the wheel spacer to clear that upper control arm. Each truck is slightly different so this will be by a case to case basis. At the most you'll need a 1/4" spacer to clear them. I would not recommend a larger wheel spacer as that will def cause a clearance issue with your inner fender liners. So far I love these tires! They're not any louder then the factory wild peaks mine came with and it's def a smoother ride with the larger side wall. ( I did have to push the front part of my inner liners in on both sides so they wouldn't hit but I did not have to cut them or do anything else. I literally just pushed them on top of the frame there. lol )
You didn't use air suspension links? I'm looking to replace my tires soon, however, I have 18" stock rims on my Rebel which has the off-road package and air ride as well. I'm Hoping these MT 35's will fit w/o rubbing
That is correct. I did not use after market links. Your rebel will clear 35's with the air ride. Air rides with the off road package start with a lift over the ones with out the offroad package.
I have the 295 60 20 Baja Boss At tires on my Big Horn Night Edition with stock rims. I only have the Bilstein level and rubbed one time up in the mountains crossing a ditch. I have about a half inch of space between the tire and the upper control arm and have no rubbing.
