Stealthdmb
- Oct 10, 2021
hello everyone, I am new here but I thought this was some good info. I was getting the dreaded engine light on the dash, had the wife take it to auto zone and get the code read. She said it was the air shutter so I figured it was no big deal. So I did some research and after finding a wiring ladder diagram I decided to get busy fixing the issue. First there are three wires on the motor one red 12 volts, black ground , and a white with red stripe. Red is hot all the time. Black is ground white with red is the comunication wire. What I found on mine was there was no resistance to ground . So after doing some reading about how the active dam may be in line with the air shutter I went under the truck and disconnected the air dam plug. Then retested the white w red stripe and the short to ground was gone. I cycled the truck on and the air shutter moved thru it’s test I then took it for a ride and the dreaded engine light is gone. Mopar has reworked this part 5-6 times as far as I can tell with part numbers. I have the newest version on order it should be here in three days . I hope this helps with anyone who is having this issue. I have read horror stories of people paying 800$ for a wiring harness fix . The shorts not in the wiring it is well protected the short is in the air dam.
