Whats your milage per tank and gallon
Duran
I get around 3 something per 23 gallon tank
I average ~430 miles on a tank, filling up with a surprisingly consistent 21.1 gallons per fillup. That’s at 1/8 tank before light comes on. I usually start looking to fill up when I drop under 100 miles range left. I’m running a 26gal tank.
Edit: I have a 5.7 non-etorque with 3.92’s and I do 60% highway.
Just finished a 2800 mile trip and got 20 on the computer and 19.66 hand calculated. My best possible on a tank is 640 with a 33 gallon tank.
Depends on speed. Per trip computer, I've gotten as high as 24.5 mpg for a 120 mile roundtrip at 60 mph. I regularly get 23 mpg at 60 mph. At 75 mph I'm at 19-21 mpg. I don't track in town mileage because I regularly use remote start which lowers the actual number.
300-320 miles per tank, 33gal, 10-11.5mpg California driving
Ok i was starting to worry everone is posting above 300 on non deisel . I average the same in so cal
I don’t envy you guys at all with that traffic. Although, you made the right choice of truck to make traffic a little more tolerable.
430 on a 26 gallon tank (refilling 23 gallons) mostly city. 70-80% city driving
High 17 to 18 mpg every tank.
Drove to Houston, actually Beaumont then back to Houston, 510ish miles per tank all highway @75mph.
Gonna slow down to 70mph next trip to Houston and see if I can get ~24+ mpg
I usually get about 340 miles on a tank with 26 gallons (actually filled up to 26). That’s hand calculated with 37s and a 6.5” lift and 100% SoCal city driving.
Wow those stats are impressing. About your tires and lift.
Im concidering some 33s on my truck i have a 2.5 in leveling kit. Will 33s clear with no rub. And what tires did you go with. Im looking at nitto ridge grapplers or the g2s.
What lift did you go woth and how was the install..
Pics would be a major plus
Rebel EcoDiesel 750 miles or just over 1200km on one 33 (124litre) gallon tank highway. Have gotten as high as 9.2L/100km or 25.6mpg, which would net about 1300km or 820 miles on a tank, but ended the trip before I used a tank.
33s will clear on a factory truck if it came with the ORP, with the 2.5 lift you could squeeze in a 34 on the dot if you replaced wheels
I have no idea man. All my details are in my sig though
Orp???
Off Road Package or Off Road Group, makes a non Rebel truck as tall as one. They add a 1” lift on all corners from factory by switching out the springs to longer ones.
According to this, I can go over 600miles on my 33 gallon tank. This is with 87 octane gas and not driving over 65mph.
Few weeks ago, did some city driving (NYC metro area) and I only got 10mpg.
800 would be a dream
We’ll be getting infinity mpg’s when that electric RAM comes out in 2024.
I’m either buying that or the Rivian in 2024.
