Hemibeast21
- Aug 14, 2021
Hello!
Not sure if this has already been done this particular way but I figured I would post up how I did my AGS mod when installing my Vararam. First Vararam fit fine with plenty of clearance with the etorque option. After removing factory intake the only part I needed to remove was the radiator cover....easy... I removed the top 3 and the second from the bottom AGS blades. I reached down with a pair of tin snips cut them in half and removed. I then took a sawzaw and cut the ends of the blades off where they had attached to the center bracket on the AGS frame. I reattached all these pieces back to the center bracket which firmed the center frame back up. There are little clips that hold them in place. I did not want to remove my grille or add the stop bolt on the AGS motor, I found this to be fairly easy and reliable. Hope this helps, if has already been discussed doing it this way my appologies.
........While I was under the hood I threw a catch can, Pulsar and Moe's 87mm TB on....
