Halogen to LED complete!
XmikeX
How did you remove the piece above the bumper and below the headlight, or do you know what that is called?
riveralg79
The bumper ends??? I kept it connected to the Grille when I removed the grille… it’s the only way they wouldn’t break…
Doberman11
Long Island, N.Y.
I just did it today, not too bad. The worst part are the front Fascias, I was so worried about breaking them. I found this on you tube and it helps with releasing the side clips.
. After that I did like [U]riveralg79[/U] said and removed the grill with the fascia, You have to squeeze your hand in there to remove the 3 lower grill mounting bolts but it's doable. I used a 1/4 " 10mm short socket and ratchet. Once it's off you can remove the clips from the rear to remove the fascia with no damage. IMG_2797.jpg IMG_2806.jpg
