295/55/22 Open Country AT III
Haggee1814
Muscatine, IA
I am looking into the new Toyo Open Country AT III and was wondering if anyone as mounted 295/55/22 on the stock 22s with air ride?
Just got my Ram limited night edition and was looking at similar AT3s possible 285/55/22 or 33x12.5x22... can’t find a lot of info or pics. Had the AT2s 33x12.5x22 F rated on my last truck a 2014 f150 limited and loved them.
Did anybody ever put the 295/55/22s on their truck? I am looking at that size as well.
I just purchased a set of Toyo OC 295/55/22s that I'm going to put on my limited. I'm changing my wheels out to the Fuel Siege 22x10 with a -18mm offset. I'm sure that I'll have some trimming to do even with it being leveled. Will post pics as soon as i get them on.
So, I just got my wheels and tires installed today! What do you guys think?
had to remove the small half mud flaps from the front, trim some plastic from the back side of the wheel wells, and remove the lower portion of the plastic behind the bumper. Now I have no rub at any level lock to lock.
Tires are Toyo OC A/T III 295/55/22’s on Fuel Siege 22x10 with -18 mm offset. I love the look and stance compared to my stock setup.
Anyone know what an equivalent tire size would be to the 295/55/22 on a 20" rim?
A 295/65/20 would be the closest. That’s equivalent to a 35.1” diameter vs the 34.8” diameter of the 295/55/22. Both are 11.6” wide.
Here is a great tool to use when brainstorming about alternatives tires sizes…
Hope this helps!
Awesome truck! Debating on doing this to my 21 limited- any change in ride comfort? Trying to maintain the ride quality
