Gravel Roads
- Aug 23, 2021
Hi everyone. First time poster here. I have a 2021 ram 5.7 and the coolant temp on the digital readout started changing from when it was new.
I've done a number of searches on this forum and others and I have not been able to find any posts similar to mine.
For the first few thousand miles the coolant temp seem to operate like others have posted on this forum. Running with a low of about 203 degrees fahrenheit once warmed up to about 215 or 217 on the highway. A few months ago it started swinging quickly as soon as I accelerate. For example if it was running at about 206 as soon as you accelerate it would jump to 208 then 210 then 212 within a couple of seconds. After maintaining steady speed or decelerating the temperature would go back down to approximately 206. Sometimes it would drop to 199 and other times it would run up to 228 and then the fans would come on. Now all of a sudden when started when cold at ambient temp the coolant temperature starts shooting up right after cold start and gets to warm up temperature within a couple of minutes. For the first couple of thousand miles it did neither of these things.
The coolant level only dropped in the overflow tank a little bit since it was new. It now has about 8000 miles on it. Out of frustration I replaced the thermostat and purged all the air. This did not solve the problem. One thing that surprised me was the coolant changed smell to a terribly stinky sickly sweet smell, kind of like the old green coolant that has gotten real hot. I see no signs of a blown head gasket other than what I just listed. No apparent coolant in the oil and no smoke out of the exhaust. I have not seen or heard of a 5.7 hemi having head gasket problems. I like this truck and this is frustrating.
I did not take this to the dealer yet. I've had bad experiences before trying to get a problem repaired under warranty with Chevrolet. The bottom line is they didn't want to touch it until it was literally broken down and not running or flashing the check engine light with all kinds of codes. I know what it's like to come up against warranty. I'm pretty sure Dodge won't touch it until it's actually blowing coolant out of the radiator or so hot that it's obviously shouldn't be driven. So I'm trying to gain some experience with these 5th gen Ram pickups so I know if others have had this problem before I go to the dealer. I know this sounds like a head gasket. The pickup is so new that I'm not sure what to think. Has anybody else had or heard of this problem with a 5th generation Ram? I apologize for the long post. I hope I listed the pertinent details. Thank you.
