Tire Pressure
GFK51
I have a 21 Limited Longhorn 10 year anniversary edition with stock 22 inch tires. What is the optimum tire pressure for these tires?
Check the label in your door jamb that looks like this. It's the suggested best pressure for a blend of mileage, ride quality, and tire life. Exception is on HD trucks that have LT tires if you don't tow or haul to max capacity you generally can run the tires considerably lower pressure for better ride.2021-07-18 09.58.41.jpg
