TX_JDubya
Recently purchased a use 2019 Ram 1500 4x4 Limited w/ air suspension. Took it in to the dealer because it was making a popping sound when you turned the wheel. Dealer is claiming both the upper and lower ball joints are bad on the passenger side. The truck as 52K miles and is 100% stock. I do not have an extended warranty and they are claiming is not a covered component under the powertrain warranty. But they are quoting me $1,900 to replace both the UCA & LCA on the passenger side. They are claiming parts alone are ~$800
Just wanting to know if anyone has experienced what I would call a premature failure of the ball joints. I have had 5 dodge rams over the last 20 years and never seem any fail before 90K. Also if this price seems to be in the ballpark for the repair (also includes an alignment and oil change).
