Can you add a steering wheel button?
1scruffynerfherder
As per the image attached (not my pic), there is a blank space on my Rebel steering wheel that I was wondering if it's possible to replace with a button?
It looks like that spot may be used in other models for an option my truck doesn't have but I'm not aware. Any info would be appreciated.
Also how much of a pia would it be to add a button there. I have a Hornblasters train horn kit on the way and I'd like the button to be pretty handy and that seems like a good spot.
ayoslickxd
thats the adaptive cruise control
vincentw56
As stated, that is where the adaptive cruise control buttons go. That whole piece is one unit so it isn't an empty panel. You might be able to put something there as long as the PCB doesn't extend in that area.
mikeru82
5thGenRams Supporter
The Palouse
Adding the button is the easy part. The wiring will be more difficult, as you'd need to see if there is an empty circuit on the clock spring to use for the new button. I think you're better off adding it to the dash somewhere.
piening2150
I don't know if it is the same in the Ram, but in my Charger the adaptive cruise block-off popped right off and the actual switches behind were still present on the wheel. Z-Auto made replacement buttons that looked just like the OEM blank and you could then program the 3 buttons to do a variety of things when used with a Tazer.
Again, not sure if the same would hold true with the Ram. I assume if it could be done, then Z-Auto would already be making replament buttons, but it wouldn't hurt to ask them.
Here's what they make for the Charger (and others)- https://www.zautomotive.com/product/z_aux_b/
vincentw56
No, not the same. You have to replace the entire panel to get the extra buttons. I added ACC to my truck and it required a new panel.
1scruffynerfherder
Thanks for the responses guys. I might have to suck it up and put a button on the dash in close reach.
