What Catch Can are you using?
Rmazzei
looking to install a catch can. Anyone using one have a recommendation on brand? After doing some research the top recommended ones seem to be:
Mishimoto
Moroso
JLT
Billett Technology
I have the Billet Technology catch can.
The color matches my truck nicely.
Easy install. Looks great. Works great.
Likely not the cheapest, but I'm happy with it.
I have the Mishimoto. Seems to work well. Sorry, no pics as of yet. I'll try to take one when I get home from work if I can remember (CRS is real!).
do you have the drain option or do you unscrew the whole can?
you unscrew the bottom of the can very easy to do.
I run the JLT and its been fine easy install looks clean, Just checked it after 1500 miles and just a bit of oil in there, but very glad i wasnt putting that gunk in my engine to "burn off"
I didn't get the drain option as there is plenty of room to get your hand in there and unscrew the bottom of the can.
Also, the bottom of the can acts as a cup, so I don't have to go find one every time I want to dump it.
Amazon no name UPR style for half the price of UPR and significantly cheaper than Billet Tech it Mishimoto. This one has the drain valve on bottom, and wouldn't have it any other way now after having catch cans on other vehicles you have to unscrew all the time. I get about 2oz every 1500 miles.
Black Oil Catch Can Tank Compatible with 2009-2019 Dodge RAM Trucks 1500 2500 5.7L 6.2L 6.4L https://www.amazon.com/dp/B0895FMYGC/ref=cm_sw_r_apanp_4Q4xI3FvXPZW5
anyone ever tries the $30 catch cans on Amazon? Just curious for cheap people
It will work just may be harder to mount or need some custom work and cut your own tubes
A $30 can will work just as well as $200 can, probably. Kinda like wearing Chippewas vs something from Payless. You can make your own for even less if so inclined. I've seen cheap plastic water separators for an air compressor used as a catch can
I use billet technology I took it off my 5.7 challenger before I traded it in for the truck. Works great
Do you have a zoomed out picture of this? trying to determine if it will fit with the RamAir.
