Reverse level
I'll try looking for a picture that someone posted a while back, but they clear!
Edit: Found it, look at post 411. He is running a 295/60 tire which is close to a 34"
Thank you. I see that you lifted yours. How're you liking it?
I'm liking it so far. MPG's didn't suffer, I get to add a little bigger tire size as well. I don't do anything off-roading, but I do live out in a farm, so the extra little clearance I got from the lift has been good. Now my factory power steps go well since it is a little taller to get in as well :D
I mentioned previously, I love the way the dropped looked but truthfully I feel like my truck has a weird suspension issue in the rear that made it drive bad cause I can feel it in the rear with the lift as well, but it's not bad compared to when lowered. I'll end up doing a 2.5F/0.5R lift by end of next year probably. I'm in no rush right now.
Im sure it'll look great when you're done
Thanks. Looking forward to it.
Zero rubbing even with -19 offset
Love it! Do you know if the stock black 20's will stick out?
No they won’t. Mine stick out due to the -19 offset wheels, Not the tires.
You could add spacers to the stock wheels if that’s the look you’re after.
Thanks for the info
