Marusho
- Jun 22, 2018
I have a 2019 and am an AC victim. I do intend to steel myself before the warranty is up this fall and visit the dealer to start the process of getting the tsb done, but even if that works, there is another design flaw in the truck that needs addressing to ever be able to tolerate the hot interior. I have the panoramic sunroof and it is pretty close to my brain.
I did some temperature tests because I am a numbers guy. On August 5, 2021, at 2pm, with full sun on my WHITE Ram, and with a custom foil windshield shade having been installed all day and facing west, and an outside temperature of 89, I took these measurements before starting the AC: Inside sunroof 158, rest of roof inside 132, interior 111, dash 120.
My hack: I bought on Amazon for $20 a sheet of quarter-inch radiant barrier of a decent brand. It was 4x5 feet, but actually was generously cut to 48x67. I cut a piece 33x48 to place between the offending sunroof fabric and the glass (photos below). I retracted the sunroof halfway and slipped this in, then closed the sunroof shade. NOTE: You have to stop the closing manually before it touches the excess bit of foil hanging down, or, for safety reasons (OK, it's hardly a hazard) the shade recoils. You must have some foil extending out of the sunroof area to prevent the foil from possibly getting rolled up with the fabric. My measurements allow 5" of the 48" to protrude but you could use less, or just attach it so it cannot retract with the fabric.
The next day I returned to the truck at exactly the same time of day, again with full sun, but with an outside temperature of 92, to see if the foil had made a difference. Now the sunroof was a nice 129, while the rest of the roof was 131. The interior, sadly, was commensurately hotter, being 115 with a dash temperature of 123. But the important thing was that I had dropped the temperature of the offending sunroof by 29 degrees.
This is particularly important because without this correction the sunroof never really cools down and as I said, it's pretty close to your brain. With the foil installed it was possible to lower the temperature of the sunroof fabric to a safe 90 degrees after 20 minutes of AC. The rest of the roof dropped to 105-112.
While I don't claim that this little fix will make the inside temperature as pleasant as (any other brand), it is a help. The limitation for me will always be the terminal temperature of the vents, which is 54 for the center vents, 60 for the outer and 73 for the under-dash area. These sound like survivable numbers but the tropical heat of (most any state these days) will overpower this puny performance.
I detest sunroofs and always have. So why did I order a white truck with a sunroof? I haven't had a thin, roll-up sunroof cover before and didn't experience this greenhouse effect with the rigid sunroof shade in my 4Runner. And I like to leave the sunroof shade open in winter to heat the truck. Unless you really like the heat I'd think twice about this option. If you already made this tragic mistake, the foil is cheap enough.
Too bad you can't search on AC (too short) or AIR CONDITIONING (since you get air filters and leather conditioning), so I hope somebody finds this. . . .
