You have to buy a package that includes power folding mirrors on the Rebel (either the Rebel Level 1 or Rebel Level 2 Equipment group). For trailer mirrors, you have the option to buy either manual or power folding. So the answer is yes and no, plus yes and no. This is all on Ram's site.Do the mirrors on the rebel retract at the push of a button if so do the trailer mirrors also do?
Sent from my SM-G975W using Tapatalk
Well, the Ram website says they're manual folding mirrors. Unless you get the Level 1 or Level 2 group (then they're power folding). If you opt for the trailer towing mirrors, they're manual.Do the Mirrors on the Big horn fold in by power or do you need the trailer tow mirrors to get that option? - asking for a friend.
No he wants them to move on their own. equipment package 2 he choseWell, the Ram website says they're manual folding mirrors. Unless you get the Level 1 or Level 2 group (then they're power folding). If you opt for the trailer towing mirrors, they're manual.
Actually, it is the opposite. The "power folding" mirrors (non towing) are often on most vehicles above the Tradesman. It is usually the very expensive levels where you can get the "power folding" tow mirrors. I have yet to find any on Big Horns... They will call them "Power Tow Mirrors" "manual fold." Oh, since 2015, they have improved the regular mirrors quite a bit with the dedicated convex little mirror. There are some after market tow mirrors that fit over the regular mirrors where it is difficult to tell they are not OEM but you do have to manually adjust them. https://www.etrailer.com/Towing-Mirrors/CIPA/CM11400.html I actually got these less expensive on mine https://www.amazon.com/Fit-System-K...ds=ram+1500+tow+mirrors&qid=1628276713&sr=8-6 They even left the lights on the OEM mirrors so you could still see them. I am NOT sure if they work on Gen 5 (DT) Rams though. They may have changed the design. These particular after market tow mirrors fit like a glove and any design changes from DS to DT models would make them NOT fit on 2019-2022's.Do the Mirrors on the Big horn fold in by power or do you need the trailer tow mirrors to get that option? - asking for a friend.
Have a 2020 Big Horn DT and they make trailer mirrors that fit perfectly over the folding mirrors.Actually, it is the opposite. The "power folding" mirrors (non towing) are often on most vehicles above the Tradesman. It is usually the very expensive levels where you can get the "power folding" tow mirrors. I have yet to find any on Big Horns... They will call them "Power Tow Mirrors" "manual fold." Oh, since 2015, they have improved the regular mirrors quite a bit with the dedicated convex little mirror. There are some after market tow mirrors that fit over the regular mirrors where it is difficult to tell they are not OEM but you do have to manually adjust them. https://www.etrailer.com/Towing-Mirrors/CIPA/CM11400.html I actually got these less expensive on mine https://www.amazon.com/Fit-System-K...ds=ram+1500+tow+mirrors&qid=1628276713&sr=8-6 They even left the lights on the OEM mirrors so you could still see them. I am NOT sure if they work on Gen 5 (DT) Rams though. They may have changed the design. These particular after market tow mirrors fit like a glove and any design changes from DS to DT models would make them NOT fit on 2019-2022's.
