Desert Dawg
Okay, this may seem like a weird thing to do but going to ask the suspension gurus here for their input. Sorry for the long thread!
First, I am currently running a 2020 Ram Rebel 4x4 crew cab with only 6600 miles on the odometer. It is currently setup with the Fabtech 3-inch UCA lift with Dirt Logic 2.5 coilovers up front and Dirt Logic 2.0 shocks in the rear married with a coil spring spacer to complete the 3-inch lift. I netted a tad over 3 inches of lift over the Rebel stock ride height which includes the new Yokohoma Geolander M/T G003 LT295/70R18 tires (34.4 inches tall). Accounting for the change in tire size over the stock LT275.70R18 Duratracs, the system actually netted ~2.75 inches of front lift (after some settling) and I am maintaining about 1/4-inch rear to front rake with the topper installed on the truck bed. The CV angles and front geometry are not too extreme but could be better along with the alignment.
My recent off-road escapade over Engineer Pass highlighted some of the limitations of my current build, at least for slow speed rock crawling trails, as I bottomed out a couple of times causing some minor damage. A recent romp on a desert romp also highlighted my limitations on approach angles that also caused some minor damage. Both recent incidents has me considering the need for a tad more lift and/or a better performing suspension.
Now considering the BDS 6-inch with FOX 2.5 Factory Series remote reservoir coilovers with DSC and Fox 2.0 rear shocks with 5" ProRide coil springs (there are no lift spacers used and I definitely get all the clearance I need along with significantly enhanced off-road performance and very smooth highway ride...but, it's 6-inches of lift)!
In talking with BDS, the Tech stated that I might be able to decrease the preload on the front Fox coilovers down to around 5-5.25 inches of actual lift. However, he stated that BDS has never tested the system with that kind of adjustment and therefore cannot comment on any effects on performance (probably knows but restricted from saying due to liability reasons). If I can reduce the front by about 3/4-inch, I could clear my garage and lower the increased center of gravity a tad more too (although still high). But having the added clearance and significant off-road performance, along with improving the stance some more with slightly more negative offset wheels/tires is tempting.
Has anyone actually done something like this? If so, any negative effects on handling, ride comfort, etc.?
Also, has anyone actually taken the BDS 6-inch Fox coilover system off-road (and I don't mean dirt roads...lol)? If so, how did it perform? Also, any feedback on highway handling, etc.?
Thanks for any constructive input.
Edit: Simplified post.
