headlight assy quit working
iutig1964
So, last night I noticed my right side low beam seemed to be burnt out. Further checking revealed that the high beam doesnt work either, nor the front right turn signal. I can see very faint light from the low beam bulb so i know its not burnt out.
Any one have any ideas other than a visit to the dealer?
Thanks in advance!!!
There isn't much you can do since none of the "bulbs" are replaceable in the LED headlights. If you are still under warranty I'd take it in to the dealer because it sounds like the headlight will probably need to be replaced.
