Any granites with black fender flares?
Kone
SEC PA
Thinking about adding matte black (oem like) fender flares to my granite color crew. Anyone maybe have this combo and have a picture? I'm then thinking of adding matching matte black oem running boards And think that the combo of black running along the bottom would look nice and contrast nice with the chrome my truck has.
I too have thought about adding some black trims to my granite. Not the flares mine are stock granite. But thinking of a matte bug sheild and window air deflectors.
Do these help you visualize?
Check out a rebel in granite two tone with night edition. Plenary of black to see up against granite
View attachment 95528View attachment 95529I got these on eBay for less than $200, and I had my OEM side steps sprayed with Rhino Liner.
That's It! Thanks!
I'm getting the oem matte black running boards so should look very similar. I have the very shiny chrome oem wheels but at some point hope to pick up Laramie or Limited wheels that have some black in the .
Yes! Thanks!!! What brand are those?
I bought them on eBay from AdvanceTuning. The fit is pretty decent. Not as perfect as OEM, but I'm happy with them, since I didn't have to drill holes in my fenders
Bushwacker 50928-02. Easy to install, still holding up well a year later.
Rebels come with black fender flares
I am thinking of installing fender flares now, but I already have my ram molded mud gaurds installed. Am I able to reuse the mud molded gaurds , or do i have to buy new ones that will fit with fender flares?
Mine required the removal of the factory mini-splash guards
It is hard for me to tale from your picture here, but do the bushwackers you installed give full wheel coverage on your tire size. I run the same tire size and I am looking for something that will give me full coverage.
Full coverage of the tread. Side wall sitcks out less than 1/4" in rear, and about 3/4" in front. I guess the axles are different widths? I would have expected the same front to rear, but it is the same side to side on each axle.
Thanks for the info. I do appreciate it. I will have to order a set.
Oh ya. I took off the painted stock and went Big Boy style with some Bushwacker pocket flares.
Love they way they turned out.
have a question im about to install mine are you placing three of the hole tabs with retainer on the top three holes on both rears?
