Parking Procedure Question
Status
Not open for further replies.
Lettika
No leaks, no black screens, no rattles, no whistles, no clunks but I have a couple of questions that the group concerning the parking lot.
  1. Have you guys seen that if you pull to a stop and hit the "run" button, the truck will shut off and automatically turn the shifter dial to park? Pretty cool!! However this scenario leaves the truck in "ACC" mode. When you hit the button to shut down it starts the truck?? It would be pretty sweet to pull into a parking space, stop, hit the "run" button and the truck shut down and put itself in park. Has anyone figured out the right procedure to get this outcome?
  2. Similar scenario, pull into a parking space. Then the ecco mode shuts the truck off because you are stopped. You put the truck in park and the engine starts again cause ecco mode is disabled in park, then you shut the truck off and exit. Must look kinda goofy to any onlookers that someone in a sweet new truck pulls into a parking spot and turns their truck on and off a few times like a severe OCD person. Has anyone figured out how to avoid this without shutting off the "auto off" every time you pull into a parking spot?
Status
