Upgraded dash speakers on HK system....
LimitedGRR
GRR, MI
Thought I’d spring for the infinity dash speaker upgrade for my HK system. Wow. What a difference with much crisper and cleaner notes. It also really compliments the stock door panel speakers now since the door carries more mid and lower tones. When I compared the 2 as far as sound goes, the HK speakers sounded horrible. Flat, monotone, not crisp at all. Comparing the 2 physically, I’d be embarrassed to show off the HK speaker and call it a quality piece. I suspect ram paid Harman for licensing the name, but harman did not give them quality pieces.
e55amg2
I wonder if it'd be worth doing the ones in the rear headliner and the center with this. I've also got the 19 speaker HK system
LimitedGRR
GRR, MI
Are the rear headliner speakers easy to replace? Crutchfield website suggests not screwing with them. Curious if they’re screwed or glued to the headliner. With rams we risk ruining our 3rd brake light seals!
Timeless
SC
It is funny how the system sounds to different people.
I have had numerous people tell me the stock system is amazing and so much better than their vehicle...and these people have premium audio upgrades in their vehicles.
I had the premium B&O in my 2019 Mustang GT and it was no where near as nice as the HK....
myles
the 2 speakers in the rear headliner are easy to replace, just pop out the plastic with a flat tool, you're going to have to pry pretty hard, unscrew the old speaker and pop in a new one. takes all of 10 minutes for both sides.
When I did it, I just cut off the old wires and crimped on blade connectors and it worked good
LimitedGRR
GRR, MI
From inside the cabin or through the 3rd brake light? Thanks
robwah
Did you use wiring harness or cut wires and use blade connectors? If wiring harness which did you use?
LimitedGRR
GRR, MI
I used these.....Amazon didn’t have the Metra which are a bit cheaper, but the speakers were 30.00 less than through Crutchfield so I was still money ahead.
myles
Sorry for the late replay, but from inside, the plastic just pops right out and you’ll see the speaker
LimitedGRR
GRR, MI
Tried to replace the rear headliner speakers and of course the infinity 3025 are not oriented in a good way to mount. Bulky magnet and the connect prongs don’t make it easy. Will probably need to drill new holes in the plastic mount plate to make it work. Tomrws project.
Nsm42
Assuming you meant 3032? I ran into the same issue. I did end up drilling the holes in the plastic to mount them.
