Tire Pressure
Tmcb
I traded in a Ram which had 18inch tires. Recommended tire pressure shown on the inside of the door was 60lbs front and 65lbs rear.
My new truck has 20inch tires. The recommendations again state 60lbs front and 65lbs rear. The tires actually show Max 80lbs. I drove off the lot with 90lbs.
My question is with the larger tires, shouldn’t the pressure recommendation be hire?
Did you buy a 2500 ? The 1500’s 20” tire psi recommendation is 36 psi
