Tonneau Cover with Rambar Installation Guide
taskhaa
Hey yall! I know many people didn't install Rambar because it's not compatible with tonneau cover. Here is how I make it compatible with only minor modification on the tonneau cover side rail.
2021 Ram Rebel
Gator Soft-Roll
Rambar (Parts# 85515959) Parts website said it doesn't fit 2021 Ram, which is misleading.
taskhaa
There are two bolts on each side of the Rambar, so we have to leave spaces for the bolts to fit the side rails.
Use your knife to cut the rubs off. It's very simple. I didn't drill any hole on the metal because it's not wide enough.
taskhaa
It fits but there are noticeable gaps. I highly recommend yall to buy foam tapes if you don't allow any leaks to happens.
Georgf
Russia
Just curious, if the Rambar protrudes above the roof, is it felt when driving on the highway? is there any noise at speed or deterioration in aerodynamics?
Sal731
It looks good. I got a hard cover. Mx4. I would be able to install but not flip all the way up to cab
taskhaa
Nossir. They are pretty tight (rambar+cover) and won't make noise at all.
taskhaa
Yessir. Same problem as well. I can't roll all the way up. I think the only thing works in this case will be a retractable cover. It's quite expensive :(
GioK68
hi, not that i can tell, being all round surfaces i assume they let the air flow, on the contrary of a storage box or a tent for example.
