Is the v6 2000 rpm vibration limited to the 4x4 models?
Fugitive
I’ve read the threads on the annoying and challenging 2000ish rpm vibration and was wondering if it was only on the 4x4 models or on both. Any insight will be welcomed. Thanks.
I am referring to below thread...thanks.
My 2019 5.7 bighorn 3.92 vibrates, I only notice it taking it easy through a town. Even my wife comments about it, so I know it’s not in my head. If I step on the gas it instantly goes away.
Probably going in and out of MDS (cylinder deactivation). To disable MDS use the gear selector on the steering wheel after putting it in drive and press minus (-), then press plus (+) until you see gear 8 selected
My truck is/was a 4x4. Another member with 3.6L 4x2 reports no issue/vibration.
I have no unusual vibration at 2000 or any other rpm in my 4X4 Pentastar.
Weird, I don't have any vibration but occasionally I will get a sort of shudder thru a school zone.
Sent from my SM-N970U using Tapatalk
I have the 1500-2000 RPM vibration in my V6 4x4 with 3:55 end. Mostly in gas pedal and a little in steering wheel. This consistently happens at this RPM range. According to most it's something we have to live with. Very disappointing for such a nice truck. I have tested others with a similar issue. Hopefully someone finds the fix. Some have tried exhaust dampeners still with no luck.
