What’s the verdict?
Rambro1776
Welp, I’m likely going to pull the trigger on this wheel setup (fuel covert 18” w/ Falken wildepeaks 34.5” 295). Truck is leveled and wheels sit flush with fender. No rub at full lock
Welp, I’m likely going to pull the trigger on this wheel setup (fuel covert 18” w/ Falken wildepeaks 34.5” 295). Truck is leveled and wheels sit flush with fender. No rub at full lock. The help I need is do I go with 35’s and do the Fox Elite 2.5” lift w/reservoirs? I go off-road quite a bit with lots of potholes and rocks
I like the look. Sorry can’t help with your question on the suspension.
No reason to swap suspension prior to the wheels and tires if you’re already level. Try it out and if you want to upgrade to the foxes it won’t cost you any more than doing it now.
Good point! Thanks!
I have those wheels in a +1 offset, they poke very slightly with 35x12.5. can't really help with the rubbing since the truck is lifted
Just ordered the same specs as you mentioned, then opted to get the Fox elite lift w/reservoir as well. Will update once installed! Awesome looking truck btw!
Pulled the trigger on the wheels today. Not sure I’ll benefit from the Fox Elite setup. Thoughts? Have 2” puck level. Tires are Falken WildPeak AT3 34.5” 295/70R18. No rub at full lock
What is the offset of those wheels? Are those the -12?
