(Solved) Undercover Armorflex Install Issue
shalakozuni
(Edit) It was clamp positioning. Thanks for the tips everyone.
I have a 2021 Ram Crew Cab Laramie qith Linex coating. I'm having issues with my install. Rails seem to sag down and in to center of the truck which keeps it from latching. Also wont close over the tailgate. Need some insight if you have it. Thanks for your help.
It shouldn't tip like that. Mine is flat. Loosen the clamps, move the rails to flat and see where the clamps align and then tighten but don't use 100 ft-lbs of torgue. Be sure the back of the clamp is as high as it can go on the truck rail and hold the rail up while tightening. They shouldn't be biting that high on the round clamping surface.
If you still have issues, I'll get a shot of mine later.
The gasket seals the tailgate well so you'll need to close the cover before the tailgate for a while.
Ya mine is kind of like that not as much though.
RC cover guides are not installed correctly. if necessary, I can take a photo as set by me. with the same cover from RC
Got pic of proper clamping?
It now looks like Biz Jet Tech's install above. Make sure the clamps are high as possible and even elevate the rails just a bit which helps with the tailgate close.
Sent from my SM-G991U using Tapatalk
