Quick photo/look request on the inside of your B-Pillar trim
SD Rebel
San Diego, CA
I was wondering if someone could check (inside passenger front) on the top of the b-pillar where the door opening molding touches the headliner, if you have the same gap I have?
I just got my windows tinted, so not sure if somehow it happened there. But I doubt it, because they aren't likely to need to mess with it. Either way, doesn't look difficult to fix, likely just need to loosen the bottom section to get enough slack so it stay ups there.
But I suspect it was a factory variance, curious to see if others are the same. My passenger side it fitted perfectly.
