Fitting 37x13.5’s R24x12 -44 offset
Chris VB
Ontario Canada
Anyone wanting to put big tires on of this caliber will be needing an 8” total lift. The problems start when you choose 12 wide opposed to 10. You can fit 37x12.5 with a 10 wide wheel on a basic 6” suspension lift but you’ll need to do a 2” body lift to fit the 13.5 wide 12 wide rim -44 offset. After doing so the clearance at turn is 3/8” off the painted front bumper. They don’t offer an 8” suspension lift yet for the ram 1500 and I’ve seen a couple modified 6” pro comp converted to 8” but the geometry is drastic looking. I know everyone bashes body lifts but I have no regrets! It looks great, dodge takes them very well no body gaps or anything just need to offset exhaust tips back up. Also need the calibration module for your speedometer and odometer. But all said and done ZERO rubbing even at full turn. Steering radius is less of course but who cares lol and it’s not that bad at all. Turn this girl into a beast! And I’m so pleased
Hustleman216
Think I may be doing something like this . I have a limited with the tough country lift and ordered 26x12 rims instead of 26x10 this may be my only option
Chris VB
Ontario Canada
Nice, what size tire you thinking? 6” suspension lift?
LITTLEREBEL
South Louisiana
I hold you responsible for me ordering a 2" body lift last week after seeing your truck. lol I was looking at 6" lifts too, but I'm just going to run it with a 2.5 lift for now and see how it performs. The best price I found the 2" body lift was suspension connection for 390.00 shipped. As soon as it comes in I'll get everything on.
Chris VB
Ontario Canada
Nice these trucks take the body lift very well. Hitch and everything looks great. Just gotta fix the exhaust tips back up
Chadtonio
What body lift did you use? Read that the Gen 4 kits will work on the 5 but that was in an Amazon review and not sure I trust it.
LITTLEREBEL
South Louisiana
The mechanic said it wasn’t a bad job because the truck only had 500 clicks on it. Pretty sure it took them an eight hour day
How's the truck holding up? Do you do any towing? I tow my camper and car trailer alot and think going that high might not work well with towing. I like the look though.
Chris VB
Ontario Canada
Trucks holding up great! I do some mild towing, with a utility trailer. And haul my 1025R diesel JD with it. Just put a new differential cap on and the oil was clean. Magnetic pad was clean. I’m so happy with it
