Rim/Tire size question after level, 2019 5th gen
HelsiBorlis
Good afternoon! I have a 2019 1500 Big Horn that I’m getting leveled with a 2.5” front end lift Friday.
Would rims with a -18mm offset and 33” wheels fit nicely on this? When i look on Ti https://1921681001.id/reRack it’s giving me warnings that it’s outside of the stock wheel diameter. I know it is, but will it work?? https://19216811.cam/
Would rims with a -18mm offset and 33” wheels fit nicely on this? When i look on TireRack it’s giving me warnings that it’s outside of the stock wheel diameter. I know it is, but will it work??
Go to custom offsets. They will have a lot of photos with trucks with similar setups in the gallery, and it will tel you whether it runs or not, and if there was any trimming needed to make them work. With that said, I’m almost positive that you would be fine with 33’s
They'll fit fine. Here's mine with 33's and -19. Im not even leveled.
33's fit on mine without a level. You'll be fine. I think a 2" lift you can go to 35's without trimming.
