Post your Rebel pics!
driver error
If you're still stuck out there, posting this pic is not the ideal way of asking for help.
Looks like you've got MaxxTraxx or an equivalent on the ground there. How'd you get out? Did they work?
haha, zero reception. This was in the middle of no where in baja, after an hour i made the walk of shame and found a local who helped pull me out.
Love the truck! What is the lift and wheel/tire setup?
I appreciate it! I went with the 6” rough country w/lifted struts and v2 shocks. Wheels are 20x10 -18 offset Fuel Rebel on some 35x12.5 Yokohama Geolander. I also have on 2” bora spacers
I have the Geolander as well. I have been pretty impressed. Much quieter than my previous Cooper STT pros, Trail grapplers and Toyo MTs. I like the tread and they handle well.
Decided to try them out and I’m liking them. They have that aggressive look the trail grapplers have.
Stripped off the ugly bed coating I sprayed on the front skid plate. I finally got around to take the whole bumper assembly off and paint the skid plate the right way. I chose a dark metallic gray instead of the black. I’m loving the color choice!
6112s upfront on clip #8 with 1/2in motofab spacer. Rear 5160s and jeep gladiator triple rate 2.5in springs, zone uca, method 18x9-12 wheels with 35x12.5 trail grapplers.
Awesome! How is the ride with those settings? Your setup is exactly the ride height and look I want, though I maybe will go with 34" tires just to take the edge off on the mpg and clearance.
Rides great! the rear springs were a pain in the a** to install but everything else went smooth. very minor trimming, ripped off that small mud flap up front and hammered up the metal tab sticking out and used a utility razor to cut off a small section of fender liner.
