2020 RAM Proximity KeyFob Programming Flashes
dbkali
Greetings,
I am trying to program a keyfob for a 2020 RAM 1500 Laramie 5.7L. I know the keyfob is supposed to flash 5 times when the programming is successful. However, I am only getting 3 flashes from all three keyfobs that I have tried. I am just wondering if anyone knows what the 3 flashes mean or if there's a site to look up the key programming flash sequence?
Thank you!
busa2009
Atlanta, Ga
Wasn’t aware you could program your own key fob
Georgf
Russia
Maybe you tried program used, already programmed in another truck fob? They say it must be new, clean key fob, or it must be cleaned before by professional locksmith.
dbkali
I have heard the same thing about the Proximity keyfobs. You will have to use a high-end programmer that can recode the keyfob, in order for you to reprogram the keyfob to another truck.
