So following a YouTube video on installing a Motofab 2.5” level I used a “pickle fork” to try to separate the UCA and sure enough I ripped the boot up. Does anyone know of a good replacement boot? Thanks in advance.
I just did too. And broke the GD pickle fork trying to separate it unsuccessfully! Frustrated!So following a YouTube video on installing a Motofab 2.5” level I used a “pickle fork” to try to separate the UCA and sure enough I ripped the boot up. Does anyone know of a good replacement boot? Thanks in advance.
Yup same here, boot all sorts of screwed up. I ordered a new upper control arm and debating on just it leave it alone. Still having been able to pop the UCA from the knuckle, prob try to use a puller.
Hello guys, This past weekend i undertook the task of installing a 2" leveling kit myself. Unfortunately like you guys and i bet everybody else attempting this with a pickle fork i tore both front upper control arm ball joint boots. I ordered a pair of replacement boots from amazon, when they arrive if they fit i will report.
You mean like this? I’m throwing in the towel trying to get this GD ball joint to break!! I’ve torn the sh$t out of the boot and the stupid ball joint still won’t break free to fix the boot even!! I even tried an air hammer which was usesless! Done and done!!
Did this end up working? If so, what part did you order?Hello guys, This past weekend i undertook the task of installing a 2" leveling kit myself. Unfortunately like you guys and i bet everybody else attempting this with a pickle fork i tore both front upper control arm ball joint boots. I ordered a pair of replacement boots from amazon, when they arrive if they fit i will report.
What puller did you get from Amazon to remove the UCA?Update... so I just removed my UCA using a puller from Amazon. The UCA has no adjustments and it’s just a direct bolt on. Easy. Took like 30 mins to do. Dealer/ other shops quoted me 500 bucks to change it and that’s without a wheel alignment. Lol. So now prob re order the Motofab spacers again and try it again. Of course then need a wheel alignment after.
Pictures are of bolt arms, the new one installed. And a before and after of my damage to the old arm boot.
Did the boots fit ? If so can you post a link?Hello guys, This past weekend i undertook the task of installing a 2" leveling kit myself. Unfortunately like you guys and i bet everybody else attempting this with a pickle fork i tore both front upper control arm ball joint boots. I ordered a pair of replacement boots from amazon, when they arrive if they fit i will report.
Were you able to replace the UCA boot without replacing the whole UCA? I too damaged the boot installing a leveling kit on my 2019 Ram 1500Hello guys, This past weekend i undertook the task of installing a 2" leveling kit myself. Unfortunately like you guys and i bet everybody else attempting this with a pickle fork i tore both front upper control arm ball joint boots. I ordered a pair of replacement boots from amazon, when they arrive if they fit i will report.
I left it alone. Decided not to lift the truck and too much trouble to put new boots on. Will just drive it until the lease is done.Were you able to replace the UCA boot without replacing the whole UCA? I too damaged the boot installing a leveling kit on my 2019 Ram 1500
Did you ever get a boot replacement? Which ones did you order?Hello guys, This past weekend i undertook the task of installing a 2" leveling kit myself. Unfortunately like you guys and i bet everybody else attempting this with a pickle fork i tore both front upper control arm ball joint boots. I ordered a pair of replacement boots from amazon, when they arrive if they fit i will report.
They're still beat up. Leaving it alone. Pumping grease into the joint for now.Did you ever get a boot replacement? Which ones did you order?
that won't hurt anything..are you using a dead blow hammer? Did you get it to break free?View attachment 87298hey guys! So I actually bent in a corner of my UCA trying to get it to break loose with a hammer. Not sure if I should get it replaced. This sucks!
