surround view camera
MTRHEAD
So. ILLINOIS
One thing i don't like about it compared to my f150 is on the ford i could drive forward up to 5mph with the front, rear, or all 4 camera's showing. It really came in handy when pulling into a parking spot or even a garage to see how close you are getting to a obstacle. Unless i'm missing something. Surely FCA could come up with a software update to correct this.
I rarely pull into anything...... Always back in. But, the only way I've found is to temporary put it in reverse and then back to drive to get the 360 on the screen.
This setting
There's a delay, but there's also a surround view app you can drag onto the menu bar to turn it on while pulling forward at low speeds
In the apps section their is an option for the 360 camera. Just drag and drop that to your favorites at the bottom of the screen. Then anytime you want to use it (like pulling into a parking space), just push that button. I believe it will work as long as you're going less than 8 mph.
Yep, my 13 didn't have any front sensors and with the sport hood... I was always 2 feet from the wall. Now, I'm 4 inches from the wall in the garage.
So, the extra 4 inches of length the 2019 has (292" vs 233") actually results in my tail end sticking out 18" less!
