Roof trim, Roof molding
oaviking06
So im gonna wrap the roof, and want to remove the trim molding. how does it come off? Clips or just double sided tape? Thanks
Yea, that was my other idea. Was looking at different options.
I did the roof.... not perfect. But after a week ill forget about any blemishes..im also just an amateur.. i was quoted $300 for the roof, i bought the same brand 3M 2080, came out to $100 with a vinyl tool kit i also bought. which i now have for future projects.
These are clips. Idiot before me mounted a roof mounted light and bolted it I the rain roof trim. If your gunna pop it off just use a pry tool and go slow. They are a little annoying to put back.
Something very interesting is that if you have the VERY LOUD whistling noise in your cab at certain speeds 70+, it's that Fxxxxxg trim. Air will get under it and you will get that noise. I put packing tape on mine and covered it up really well and the noise disappeared. If you tap on it and get a small click like it's not attached very well, that is the issue. I am going to get some new trim, clips and small diameter hollow trim tubing and put it all back so it will take care of the issue.
My truck is a 2019 Limited that I really like a lot.
Did you ever buy the trim? If so from where? Thank you.
