ultimate "TRX"?....
HemiDude
Ohio
That thing sounds effortless on the dyno! I would love to take one of those on a long drive just to listen to that engine and exhaust sing
SD Rebel
San Diego, CA
Did you see the rear wrap up?
The Chart said 583 max HP.
Malodave
At assumed 15% driveline loss for RWD it should have been at 597 hp at the rear tires (based on 702 hp flywheel), but that's just a rule of thumb. Considering the TRX is a full time 4WD, not sure how doing a rear dyno only test would effect driveline loss, even assuming they disconnected the front shaft.
4WD car has around 27%-30% driveline loss (Flywheel, Clutch, Gearbox, Front Diff, Front driveshafts, Propshaft, Rear diff, Rear driveshafts, Wheels), but that's on a 4WD dyno.
