tire pressure question
deadringer
I know it has been discussed here before, but I was a little surprised that the tire pressure listed for my BTS bighorn is 32 psi. T hat seems low to me. I was thinking of running 35 psi. Thoughts?
Is your TPMS yelling at you? If not, don`t worry about it. Just follow the recommended inflation pressure for your truck.
Go for it. See if you like it. Down the road, check wear at the center vs at the outside edges.
i run the OEM 275/55/20 Bridgestones and my 275/60/20 Rotiiva AT Plus (E load snow/All Terrain) at 35 normally and 40 when towing.
