6112s/ fox 3in lift coilovers?
DevonBirch
Does this make any sense? the 6112s on clip 8 provide 2.6 inches of lift on non rebel/orp trucks which nets 2 inches on rebels. fox 3 inch lift coilovers lift a non rebel 3 inches but still only 2 inches on a rebel. if 2.6 inches equals 2 inch rebel how does 3 inch also equal only 2 inches. wouldn't the fox 3 inch coilovers equal about 0.4 more lift on a rebel than the 6112s. Ive been doing alot of research on the forum and from what members with both setups https://19216811.cam/ say they got 2 inches of lift.
Does this make any sense? the 6112s on clip 8 provide 2.6 inches of lift on non rebel/orp trucks which nets 2 inches on rebels. fox 3 inch lift coilovers lift a non rebel 3 inches but still only 2 inches on a rebel. if 2.6 inches equals 2 inch rebel how does 3 inch also equal only 2 inches. wouldn't the fox 3 inch coilovers equal about 0.4 more lift on a rebel than the 6112s. Ive been doing alot of research on the forum and from what members with both setups say they got 2 inches of lift.
Fox uses their own springs which will lift the truck differently than the spring that comes with the 6112. It's also using a more precise compression nut rather than a clip/recess on the strut. I don't think you can't compare the numbers.
You're confusing using the stock coil vs the coils that come on the 6112's and the Foxes. The stock coils have 1 inch of lift. The other two don't.
