33X12.50R22 Fit 2021 Ram Sport perfect
Bondadoso
Hey all been toying around with a few tire options but settled for the BFG K02. As you can see from the pics some tight fits but zero rubbing. Tough to install without damaging face so careful where you go, but got’er done with a little elbow grease, tire lube, and a coats machine with third arm.
2021 RAM 1500 4X4 Sport
These look great! Have a 2021 Laramie with the 22”, no bags. Want more tire wall, but no spacers or leveling. Did you get any rubbing? Hear a lot about rubbing in reverse and tight turning. Thanks for input.
only question i got is do you have any spacers at all? on the wheel? do you touch the uca?
How have you liked these tires ? Do you have air ride or normal suspension and had it affected ride?
looks like he has normal, you can see the strut and springs on one the 2nd to last picture. An air ride truck would just have a massive air bag and no springs
Thanks for sharing this. Thinking of getting the same tires for my ram, maybe even 35’s with a leveling kit. Question I had was how much do they stick out past the fender? From the pic it doesn’t appear to be very much. I’d be installing on stock rims as well. Appreciate the info.
