What version of Uconnect?
fxdrider
For any of you who had the Uconnect update that was distributed this week, what version of the software do you now have? I'm trying to see if I'm current, or if I'm still on the previous version.
I tried checking the Uconnect website. It said my VIN was up to date, but I don't trust it. Just trying to verify.
My radio (8.4 NAV) updated to version 20.37.11.
According to U-connect website my 18.23.29 is up to date!
I haven't attempted to confirm this, but I suspect the site is just a bit of code to always say that rather than attempting to actually check. Updates are rare enough that it's even right the vast majority of the time!
I checked the website and it said it was up to date, and yesterday on my way back from the store I get hit with the update.
Want to check what version I have, the website simply says I'm up to date but I want to verify that. Any way to check in the truck, 8.4Nav Uconnect.
Push the two outside menu "buttons" on the 8.4" screen for about 10 seconds and you will enter dealer mode (these are the touch screen menu buttons on the bottom of the screen - the first on the left and last one on the right, no matter what they are).
I don't have my truck to take pics right now but it's in one of the options in the dealer menu that will show you the current software version on your truck.
Mine shows up to date on Uconnect site as well, but compared to what versions are running, I am infact not current. Typical Uconnect woes.
Got it, thank you! It appears I'm running 20.42.11. Needed it to do further research on why my iPhone is suddenly giving me a "device not supported" error on my radio. Turns out a swap of chargers solved my issue.
I haven't had an update since March 2020, but I have no issues so no complaints.
I'm on 19.49.13 btw.
My 8.4 Nav updated to 20.42.11 last night. I believe this is the first time I was queried to install an update since acquiring the vehicle back Nov. 2019. Not sure if this typically happens in the background or not.
It doesn't upgrade in the background. It will always prompt you for confirmation.
Is there a way to manually update the software with a usb card?
The only way I know that you can do that is to enter your VIN here: https://www.driveuconnect.com/support/software-update.html
If there is a software update then I think you have the option of downloading it to a USB to put in your truck.
So far I don't know of anyone who has had a software update available when they plug in their VIN. I check regularly and it's always told me my software is up-to-date...even when an OTA update has appeared later that day.
