TRX rear tow hooks?
Kdixer
Has anyone researched adding the TRX rear tow hooks to a rebel?
I have looked online for part numbers with no success.
silverWS6
EPTX
There's a thread about this somewhere with pictures. I think on the TRX subforum.
The Rebels dont have the mounting points for the rear tow hooks.
Shifts And Grins Fab
5thGenRams Vendor
5thGenRams Vendor
Gilbert Arizona
I was asked about this recently. It won't be until around June but I did look at this and there are places to secure brackets for hooks.
SD Rebel
San Diego, CA
No, they will not directly mount unless you fab it to fit, it's a completely different hitch system. They would look nice though, I understand wanting them for that.
However, if you just need a recovery point, I recommend instead you get a shackle hitch receiver, they are $30 bucks or so and can be removed when not needed. Probably stronger as well.
5thGenRams Vendor
5thGenRams Vendor
Gilbert Arizona
Fabrication is what I do. Sorry I wasnt very clear. Sometime around June I am hoping to be able to devote the time to fabricate brackets to attach the hooks. They will be solid recovery points.
SD Rebel
San Diego, CA
That's awesome! So a bracket system that you can design and fabricate for sale? I'm sure there would be a lot of takers for that.
SD Rebel
San Diego, CA
So why not switch to the whole hitch setup with the hooks?
I think someone mentioned that part of the frame is different, the TRX doesn't actually have exactly a 1500 frame, it's more of a hybrid with some heavy duty sections. That it's probably easier to get the hooks to fit our hitches than to get a TRX hitch to fit our frames, but honestly who knows at this point.
Nukegm426
That would be odd... just the sheer manufacturing cost to make a separate frame for what is essentially an options package is crazy. But who knows maybe your right.
SD Rebel
San Diego, CA
RebelWraith
Polymath
Montclair, Va.
Bolt patterns and mounting are likely different. If my design works it will also be a lot less expensive to buy the brackets.
Would your kit be brackets to mount the factory TRX tow hooks to standard RAM tow hitches? If yes, take my money. I've got the hooks, but the hitch isn't available yet.
I've seen the TRX hitch up close and compared to my Rebel. Even the online diagrams shown them to be almost identical. The major difference is where the mounting tabs are welded in for the hooks.
5thGenRams Vendor
5thGenRams Vendor
Gilbert Arizona
Yes, my idea would be a bracket kit and the factory TRX hooks would mount to the brackets. I'd be very interested to see if the receivers for the two trucks are interchangable. I'd be surprised if they are but hey they've surprised me before. Either way, the brackets I plan on making will save people time and money of having to replace a receiver hitch they already have.
RebelWraith
Polymath
Montclair, Va.
Would much rather purchase the brackets from you and help you with your business. I'll buy a set as soon as you make them. 👍
5thGenRams Vendor
5thGenRams Vendor
Gilbert Arizona
I appreciate it!! I was going to make them when I was done with my other prototypes but I think I may bump them up on the list before I pull my factory bumper off. I have a good friend with a 2021 Rebel but it's much easier to use my truck as opposed to borrowing his for a day.
