Post your Rebel pics!
Finished my wrap. Avery Dennison satin dark gray.
Addictive Desert Design Front Bumper with Baja Design Onyx 6 and Smittybilt X20 Winch (the ADD bumper was only tested with Smittybilt and another brand - I wanted a Warn). I also installed 3.5" round generic Amazon fog lights. May switch to Baja Design S1 in the near future for a wide beam.
The front got lower with the bumper (approx 100 lbs) and the winch (almost 100 lbs). I need to lift the front...thinking about Bilstein 6112's?
Nice! Just need some aggressive wheels to go with that aggressive bumper! How did u mount those pods? The 6112's are good for the money.
Thanks! Yes wheels are definitely something I want to get in the near future. The fog lights? I just took my time to aim them and drilled a hole through the bottom of the bumper. I tapped into the stock fog light harness so they are controlled by the stock fog light switch. I got 3.5" led fogs off Amazon but they are spot pattern and not as good. The Baja Design S1 wide beam look good and are smaller so they should work better.
Good to know about the 6112's. Thanks.
Raymond
Rebel 12A
2” ReadyLift level w/UCA’s
18”x9” Method NV605 et-12 wheels
35x12.5 R18 Nitto Trail Grappler M/T tires
Mopar aluminum off-road running boards
TRX style triple orange LEDs (we don’t have to say “Raptor style” anymore :D )
‘Found some grey caps’ front license plate holes delete
Matte black ‘RAM’ vinyl covers on grille
Some other small mods etc
Rebel 12A
Awesome! Which TRX style lights?
Rebel 12A
I want 35's so bad! That looks beefy!
So, I literally looked at the manufacturer specs for many, many 35x12.5 tires out there (both A/T — but more aggressive A/T’s, and M/T) and this Nitto TG MT is one of, if not the biggest 35x12.5 out there by actual measured specs.
Most 35x12.5 are actually like 34.5-34.8 and most are listed at exactly 12.5 width. Same with the A/T’s. These Nitto’s are listed at 35.04” and 13.39” width...
The downside (besides cost): most 35x12.5 weigh about 72-78lbs... These Nittos weigh like 81lbs. That’s a heavy asz tire.
You mean like, which actual lights did I buy?
Yes... Thank you!
I finally decided to pull the trigger on some wheel/tires. It may just be me, but I couldn't stand the look of the stock wheels any longer (not a fan of the machine finish). I blame this forum for showing me how dope you can make a rebel look haha. I couldn't believe how expensive all the places around me were wanting for Nitto Ridge Grapplers (35x12.5r18). Average selling price was $400-$450 a tire. I randomly checked amazon and they had them for $337 a tire. They just came in and thought I would share. My wheels will be here Tuesday.
Those look great, nice find on the price! Curious what install ends up costing you.
Im curious if anyone has had their factory Rebel wheels powder coated? I actually like the wheel pattern quite a bit, but also not a huge fan of the machined look. Actually, I’ve been looking for dark gray colored wheels for my black Ram.
  • Jako
