Bwarren2
- Aug 9, 2018
My .02. I got the Nfab ones and now that I'm really using 'em to get in and out since the 6" lift was installed I'm noticing my footwear is hitting the lower rocker panel. Keep that in mind when your buying these.
Nope we're on the same page.I did read a review where someone said these steps are too close to the body, so even though they are 6 inch step, you really get to use about 3.5 inches of the step. Are you referring to something similar?
After having amp power steps on my last truck with a 4-1/2" lift I could never go back to a fixed running board, Amps just put the board in the perfect spot for getting in and out of the vehicle especially when they're lifted and fold away almost completely out of site. And the engineering and quality is truly top notch. Helps save wear and tear on your seats as well, you don't have to do the butt slide getting in and out breaking down the foam on the outside seat bolster. Just my 2 cents
Just got released a week agoif they made them for the 19's that would be an option.
Part number 76240 01a
You get them from autoplicity? Thats the best price I found so far at $1340Thank ya sir, ordering now..........anyone wanna buy some gently used N-fab steps?
$1070 very nice, I found a display set for my last truck never installed on a truck just one side was mounted on the wall in a showroom electrical was never connected, picked them up for 900. not likely I'll find a deal like that on a set for my Ram anytime soon.Ordered from my buddy who got me the lift. $1070 is cost on 'em. Use that figure to negotiate.
For the AMP ones? I've installed 2 sets on the 2500 and Tundra. Based on being under my truck, you'd mount the bases to the studs under the truck, mount the board to the area then hook up motor. Run wire from motor to OBD2 port and repeat for pass side except youd hook the wire into and existing wire from the driver side. Prob 3 hours total.how easy will install be?
