mopar lift kit for 2019+ 1500
ramhouston
Houston, Texas
If i install the mopar lift kit on my truck, what will be the largest tire size i can run without modifications? I also understand that wheel offset plays a factor in fitment.
thank you!
I wouldn’t swear to it as I’m not running anything yet. But I have been looking at lift and wheel/tire options. My understanding is that with a level you can run 33’s, and with a full lift you can run 35’s (with the proper wheels and offset obviously). So with the mopar 2 inch lift you should be able to fit some 35’s, as long as you’re modest with the wheel offset.
What do you consider as modest offsets?
My truck is stock and I fit 33 no problem. You can Do 2” lift up front will fit 35’s.
I won’t be planning to run stock wheels.
I had -12 offset wheels on 33’s. I could of fit 35 with slight trimming. I did install bilstein 5100. So I was gonna adjust them to fit the 35. Just haven’t done it yet.
Running 34.6" tall 295/70/18 on a 2019 new body style. I have just the slightest hint of a rub on the inside rear of the front wheel wells. I am thinking the 2" Leveling kit will fix this. Hope that helps...I can not speak enough about how much I like the Cooper AT3 XLTs...awesome tires. and Quiet too
Running 285/65R20 (34.6" tall) Goodyear Ultraterrains with a 2" Mopar lift and stock wheels.
Looks good! I’m thinking about the same tire and size. So this is full stock, before a lift? I’m looking into either a 2” or 3.5” now, but unsure of what lift kit. You decide on a lift?
