275/65R20 Stock / No Lift?
KirkDS
Trying to max out my stock suspension / 20" wheel combo. No lift at all.
Curious if I can get away with 275/65R20 or if 275/60R20 is the biggest I can go. Looking at various AT tires... Toyo AT3, Falken, Nitto, General, etc. Been reading / searching posts for quite a bit and haven't been able to really find out if this size works on stock / no ORP. Thanks!
275/65 r20 might rub the wheel liner/mud flap at full lock in reverse, a 275/60 r20 will fit no problem. A 285/60 r20 might be another choice as well
I just put in an order for some Falken 275/60R20 on some new 20x9 Fuel Beasts to replace my stock Limited 22".. I pondered going 285/55R20 but that would've been an additional $400 and a hit to the MPG. Will post pics and let you know how they run once installed next week!
Awesome, thanks!
Im looking to do the same. What did you find out? I was told 265/60R20 was the best option to ensure no rubbing.
Pics??
So, I ended up going with Toyo AT3 275/60R20. I think it's the perfect size for these tires with no lift, so I'm glad I didn't decide to go bigger. Hopefully I'll get a level / lift at some point and try something different, but I'm super happy with things so far.
Looking sharp. Here is 275/65/20 KO2s with Bilstein 5100 front level. The snow pic is after the front settled a little. Other two are fresh install; looks a little nose high but it's not at all. About 1/2' lower in front.
Looks good! I had considered going up to 275/65, but I didn't want to level or put in a lift so I opted to go with slightly smaller tires. Also saves $400 because a larger size would mean shifting into LT sizes that I don't need since I do no towing.
Just installed LT275/65/20 on stock wheels, went with Scorpion All Terrain Plus. Stock height for now, bit of rubbing on sharp turns from piece of plastic up front. Planning to do leveling kit as well bit later. Happy of the look and drive so far!
They are raised, but not that much to reflect on pictures. They actually have white on one side and black on other, you choose what you want during install time.
Well, I just got what you mean :) No, they are coming just like this, raised with white on the out shape, not fully painted. Was planning to get paint and fill the rest :)
285/60 nitto ridge grapplers. Hostile Rage 20x9 +0 offset. No rub, or any issues what so ever.
Been looking at old threads for this size and found yours great looking truck
LtT285/60/20 says it measures 33 inches, that should fit with no rubbing on a 2025 limited with off road package? anybody know? tire rack wouldn't confirm they would fit?
